1. Stacy Helget's Avatar
    This has happened to me before about a month ago... I can not make or receive calls. All incoming calls go straight to Voicemail. I was able to fix it the last time but can not remember what i did or where I found the solution. Can anyone helP? I have not done or downloaded anything different before this happened.
    03-03-2014 06:49 PM
  2. Almeuit's Avatar
    Ensure that airplane mode isn't turned on as this cuts all the radios off.
    Sent from my T-Mobile Note 3 using AC Forums.
    03-03-2014 06:51 PM
  3. Stacy Helget's Avatar
    Yes, I have checked that, it is off... Thanks tho!
    03-03-2014 07:05 PM
  1. Replies: 107
    Last Post: 03-30-2016, 05:41 AM
  2. S Note for PC - sync help
    By sandiegosteve in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-13-2015, 06:55 AM
  3. Is micro SD making a comeback in the HTC One (M8)?
    By JeffDenver in forum HTC One M8
    Last Post: 03-27-2014, 05:26 PM
  4. Replies: 4
    Last Post: 03-07-2014, 10:32 AM
  5. Help! Evo stuck in loop
    By kkeev in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-04-2014, 12:20 AM
