1. Kevin Hanes43's Avatar
    have been getting this message when I hit on just a certain text message.... "Unfortunately, Messaging has stopped" Also when I send texts i looked in the message details & was wondering why does it say in Cause Code: Addrs. Vcnt., 0 what's going on? I've had nothing but problems with this phone
    05-13-2014 03:51 PM
  2. jeff1999's Avatar
    I'm having the same problem also; my mass texting is not working and every time i try to send a text is says that "unfortunately messaging has stopped". It also wont receive messages when its in MMS. This problem just started when I upgraded to the 4.4 version. It worked just fine before that. Does anyone know how to fix this? Thanks
    06-01-2014 12:13 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Try clearing the system cache partition: https://motorola-global-portal.custh...he/action/auth
    06-01-2014 12:33 AM
  4. jeff1999's Avatar
    Thanks for the reply; i tried this but it the text messaging is still not working. Would doing a factory reset fix this problem?
    06-08-2014 02:36 PM
  5. B. Diddy's Avatar
    A factory reset might help, but it's hard to tell. As long as you don't mind the hassle of restoring your phone afterwards, it's fine to try it.
    06-09-2014 12:05 AM
  6. jeff1999's Avatar
    Ok ill give it a shot. At this point its worth it to get my messaging working again
    06-09-2014 12:57 AM
  7. psychoD33x's Avatar
    I had a similar problem on my maxx. I got fed up and tried a different app for messaging. Switched to textra and it works fine
    06-10-2014 10:35 PM
  8. SherryH1962's Avatar
    My coworker's Droid Mini sms notification kept beeping at him all night even though there were no messages coming in. He had to turn off and restart to make it stop. Any suggestions as to what might have caused it?
    03-17-2016 10:25 AM
  9. B. Diddy's Avatar
    See response here: Droid Mini-My co-worker's phone received notifications for text messages that were not there.
    03-17-2016 12:54 PM
  1. DROID MINI: SU2-3.3 Update
    By Ry in forum Motorola Droid Mini
    Last Post: 05-20-2014, 03:50 PM
  2. DROID ULTRA: SU2-3.3 Update
    By Ry in forum Motorola Droid Ultra
    Last Post: 05-20-2014, 03:49 PM
  3. Problem Updating Android OS
    By David Camilleri in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-14-2014, 08:55 AM
  4. DROID MAXX: SU2-3.3 Update
    Last Post: 05-13-2014, 01:12 PM
  5. Internation Unlocked Version WiFi problems
    By kirby3021 in forum Samsung Galaxy Note 3
    Last Post: 05-13-2014, 12:20 PM
