1. Jeff Smith13's Avatar
    My Motorola mini turned off by itself today and I can't turn it back on. It had plenty of battery prior to turning off. Anyone know how to fix this?
    05-22-2014 08:37 PM
  2. Big Jim T's Avatar
    Mine too...
    05-23-2014 09:11 PM
  3. badcookiecliff's Avatar
    Have you plugged it into a wall charger? Will it turn on at all?
    05-25-2014 05:42 PM
  4. sdweberg's Avatar
    This just happened to me, thought I was gonna have to go to the Verizon store. But here is what worked for me.
    I carefully removed the small SIM card, by using my fingernail under the volume control buttons. (Hold the phone with the screen facing up, and make sure you notice how the SIM sits in the tiny container as you pull it out.) I left it out for like 10 minutes, not sure if any certain length of time is necessary. Then I carefully slid the SIM back into the phone, making sure it was not slipping out of the little container as I pushed it back in. Finally, I held the power button down for a few seconds until I saw the Motorola logo come on, and the phone booted up normally. (Note that I tried several times to power it on first, and then I had left my phone off for about an hour before I tried the above.)
    Good luck to all of you who end up having this same glitch!!
    jordan steuber likes this.
    08-30-2014 09:15 AM
  5. izabayel pavlikryan's Avatar
    This work and was really helpful by any chance do you know how to fix the same problem with a Samsung tablet?
    01-23-2015 06:34 PM
  6. AirForce122's Avatar
    Thank you for sharing. This worked well and my phone is back working again.
    03-24-2015 10:29 AM
  7. vzwuser76's Avatar
    My brother's Droid Mini had a similar issue. He checked the weather and put it back in his pocket. After that, it started kind of a bootloop, without booting. What happened was it would vibrate for a second and the screen would turn on, but it was blank. It would stay on for about 5-10 seconds, then turn off for around 15-20 seconds, and repeat. Removing the Sim card didn't help, nor pressing the power button and volume up button (simulating a battery pull). If you pressed the power button to turn on the screen, the led would flash red a few times.
    I called a local repair shop and they were adamant that it was water damage. The only problem was it wasn't anywhere near any water and the weather right now is extremely dry. We bought it used and he figured it must've been sold after the water damage, but it's run fine for about 4-5 months. But he wouldn't budge on that being the solution.
    So I called Motorola, and the tech had me hold down the power and volume down buttons for 2 minutes, after which the screen appeared that let's you select recovery, factory, etc. But the phone was too low on battery and powered off. So he instructed me to put it on the charger for a few hours and then do a wipe of the partition chache. After it was on the charger for about 15 minutes I heard the startup sound. I did clear the partition cache and it's been running fine ever since.
    I don't know if this is the same issue as what the OP is experiencing, but I figured I'd put this here in case anyone else has the same issue.
    03-25-2015 08:14 PM
  8. Billie Helton's Avatar
    This is the only thing that worked to turn mine back on this morning. Thanks!
    08-03-2015 11:32 AM
  9. MellyC82's Avatar
    Thank you so much for the info! I held down the power and volume buttons all together and it turned back on. It was a relief to find out that it's just a resolvable glich and not that my phone broke.
    10-30-2015 10:24 AM
  10. jordan steuber's Avatar
    My phone is doing the same thing so i tried that and it didn't work like what so ever i charged it for 10 hours straight and still nothing it wont work what do i do??
    03-30-2016 10:28 AM
  11. jordan steuber's Avatar
    im trying it
    03-30-2016 10:33 AM
  1. Software update today on my unlocked M8
    By bigoldthor in forum HTC One M8
    Last Post: 07-10-2014, 05:41 AM
  2. thoughts on owning moto X months after purchase
    By eric002 in forum Moto X (2013)
    Last Post: 05-25-2014, 01:47 PM
  3. Screen Casting was live on my Nexus 7
    By TKDnerd05 in forum Google Chromecast
    Last Post: 05-24-2014, 04:48 PM
  4. Installing ROMs on Galaxy S4 I337
    By sympathizer in forum AT&T Samsung Galaxy S4
    Last Post: 05-24-2014, 12:39 PM
