I just bought the Verizon 1820mAh extended battery for the Droid Pro, and it still sucks. I'm running the GB OS, have no GPS or Wifi on. I'm running Juice Defender to help preserve my battery by turning off the data when my screen is off. I haven't been browsing or loading any applications. I took two 10 minute calls or so, and have been texting pretty much non stop though. The display setting is on auto-brightness. I'm not sure if this is normal, but from 10 AM to now 3:35 PM the battery has drained all the way to 50%! I got rid of Advanced Task Killer the other day, and the only apps that run in the background are the regular Task Manager installed on the phone, Startup cleaner, Antivirus Free, Where's My Droid, Auto Ring (so it rings for a certain contact when she calls even on vibrate), and Watchdog Task Manager. All my other downloaded apps are set to auto-kill after they're idle for 2 minutes. I checked my CPU usage and it's very low, as expected. I have my Gmail emails pushed, but I don't have any other emails or social networking programs. I have a few widgets, but they're nothing fancy. It's the calendar widget, a cache cleaner widget, a battery widget, a memory cleaner widget, and two contact widgets. I check the battery settings and it says 65% for display, 16% for voice calls, 8% cell standby, 8% phone idle, and 3% droid OS. I'm not sure if this is normal. It's my second day with the new battery. The directions said to charge it up all the way before using it (I didn't read this... oops), and I drained it from the initial 60% down to around 5% before charging it all the way back up to 100% again. I'm sure that's not a problem though. Any suggestions or ideas? I don't know if this is normal or not. I seem to be running a pretty clean system. I didn't know frequently texting would run it down this much, especially if I turn off the display in between texts as well.
