Results 1 to 1 of 1
- 11-18-2011, 07:10 AM
Thread Author #1
Display Usage
Hello All,
I have the extended battery for my phone I think the 1700mwh battery that I got from VZW.
I can bearly get 8 hrs of mostly standby out of this phone.
When I go in and look at the battery usage it tells me that the display is using 45+ percent of the battery.
I went to a corp store yesterday and they factory reset the phone, this battery is only 3 months old.
When I woke up this morning after sleeping almost 8 hrs the display said that it had used 45%, the phone was not plugged in all night, it was just sitting on the night stand. This doesn't make any sense.
I also have the X2 with the standard battery and I woke up and it told me Idle time was like 70%. I would expect the Pro to show the same.
Any help would be appreciated it.
Thanks,15 Years of Verizon Contracts
__________________________________________
Audiovox 405 -> Kyocerya 2035 -> Kyocera 3035 -> Nokia 3589i -> Nokia 6256i -> LG EnV2 -> LG Dare -> LG Versa -> Droid OG -> Droid X2
Reply
