1. ak2j's Avatar
    Is it possible to root the pro running the latest android version 2.3.3? If it is possible where do I find the instructions of how to root. This is my wifes phone and battery life is poor!! I am looking for nothing more than improving battery life. Thanks for your help.
    12-09-2011 12:32 PM
  2. badcat's Avatar
    12-16-2011 04:18 PM
  3. ak2j's Avatar
    thanks Badcat!!
    I am now rooted...any good roms out there?
    12-21-2011 12:21 PM
  4. badcat's Avatar
    thanks Badcat!!
    I don't know. I still haven't gotten around to rooting my Pro yet. I'm thinking about it but just haven't done. Was it as easy as it seems?
    12-21-2011 06:02 PM
  5. ak2j's Avatar
    Yes it was. Everything I have had time to test is working perfectly.
    12-22-2011 12:25 AM
  6. badcat's Avatar
    cool. I'm glad it worked out for you. I might give it a shot next week while I'm off of work. Have a good Christmas!
    12-23-2011 08:39 AM
  7. ak2j's Avatar
    thanks badcat, merry Christmas
    12-24-2011 08:03 AM
  8. ak2j's Avatar
    have ran into a couple of problems after rooting... I cannot edit or add contacts. Does anyone have any ideas how to repair this?
    12-31-2011 11:53 AM
  9. dankgage's Avatar
    Few tips from a rookie...
    I boot looped my Droid Pro, but on power up if you hold R and M keys down it will boot to some console. You can then press Volume Down and Camera to get to the "Factory restore" screen which will roll you back to 2.2.1.
    From there I ran Gingerbreak and it rooted it just fine.
    If you run ADB SHELL to access the Droid a first command is often SU to enter super user mode, but you need to make sure you watch the droid screen because it will ask you to confirm allowing SU mode to the shell user. After that you can do whatever you need from ADB.
    I do appear to be stuck, with 2.2.1 and can't figure out how to bring it forward. Any additional advice there is appreciated.
    04-25-2012 10:30 PM
  10. thisdieingdream11's Avatar
    Hey could anyone give me or send me the 2.26.20 sbf . I cant find a link to dl it. So if you could please!
    04-28-2012 06:03 PM
