1. ludo_z's Avatar
    Hi users
    i have one month old Motorolu Pro+ from GB and for my using is EXCELENT phone (before using Galaxy S).
    Only have one big problem - with camera , works two weeks and from uninstal Flashlite - i have trouble ...."oops,cannot open camera. Please try again later".
    I run master reset and work some days and repeat problem with camera. When i repeat master reset phone dont boot and i must reinstal original ROM - and camera dont work - i have same problem.
    Can you help me ?
    thanks ludo
    Android version - 2.3.6
    ROM - 5.51Q-110_ELW-TA-36
    Kernel - 2.6.35.7-pref+
    lupeum likes this.
    07-15-2012 02:19 PM
  2. lupeum's Avatar
    Hi there,
    have you fixed it? I have the same problem...I tried to delete the camera app, but noting.
    Thanks
    12-14-2012 08:49 AM
