Results 1 to 3 of 3
    rwbta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default 3g not working after factory reset
    When you do a factory reset, you get a message about losing data and installed programs but they don't tell you that you will lose 3g capabilities.
    Apparently the only way to get it back is with a code. However, I am currently living in Brazil and am no longer a Verizon customer. Does anyone know the code to get back 3g?
  2. #2
    cyanogen-man's Avatar
    Posts
    Global Posts
    1,049 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ice cold sandwich aokp
    Default
    OK if your not a customer then that's y if your going to use the network it has to be activated with Verizon. It if your not giving them money then no data service it becomes wifi only
    INSPIRE AOKP ICE COLD SANDWICH ROM
    rwbta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 3g not working after factory reset
    I've been trying to fix this for over seven months; then I found the answer a few minutes after posting this question. I needed to add an Access Point Name APN. In Brazil, TIM has six available. My Droid Pro would only save one of them. Here it is; hope it helps others with the same problem:
    Name - TIM CONNECT FAST 72404
    APN - tim.br
    proxy - not set
    port - not set
    Username - tim
    Password - tim
    Server - not set
    MMSC - not set
    MMS proxy - not set
    MMS port - not set
    MCC - 724
    MNC - 04
    APN type - not set
