04-20-2017 07:06 PM
50 12
tools
  1. Steps Parku's Avatar
    Damn!!!!!!!!!!! the whack trick worrrrrrrrrrrrrrrrked like charm. i spent days online sorting out apps to fix my wifi that was stucked on turned off, it always says turning on for days without turning on actually. then i came across this site. i saw everyone's feedback about the whacking trick. I ignored it actually, continued to look for more crappy wifi fixers.apk. but none worked. Finally i came back here to give this a simple try. First, i gave it a serious palm slap at the back. It wouldn't bother at all, then i took off the back case. took all emotions aside. and Gave it a hot slap at the back again, Still it didn't even bother. so i took off the battery and restarted. And bingo!!! it came on with wifi fully connected. I am enjoying my phone now. and thanks alot for this whack trick. infact. i am gonna need to keep my palm dry and ready for it at all times lol. Thanks a million. don't hesitate. try this whack trick if it's not working, try again and restart several times. It will surely work.
    My Device. HTC Velocity 4G (Vivo) Rooted with custom Android 4.4 kitkat from pacman rom installed.
    03-21-2014 05:54 AM
  2. Karma Wasson's Avatar
    didn't work for me Bluetooth won't turn on either
    03-21-2014 01:51 PM
  3. sukant gouda's Avatar
    Ok so I tried to turn on my WiFi in the settings and it would say turning on then stop and say error. I've restarted my phone, done a factory reset and even used a WiFi fixing app. Anyone know how I can fix this?
    03-22-2014 08:50 AM
  4. Jessy Blaze's Avatar
    No amount of whacking or rebooting after slapping worked.
    I've been trying to fix this for days & have spent like 10 hours trying to get my wi-fi working on the S4. I don't know what else to do or where to go from here. Everyone just tells me to get it replaced (which will cost a bunch of money even though the phone has not worked), I would rather fix this for good!
    I have a feeling I have the Telus ROM firmware with 4.2.2 on my phone that is originally Rogers... could this be the problem?
    04-04-2014 03:10 PM
  5. fuzedkilla's Avatar
    I have a problem too involving the wifi. My wifi win't turn on. It will just say wifi turning on, but then it will go back to wifi off. And I don't have a cellular data plan. Can anyone help me with this problem?
    Chenal Gordon likes this.
    04-26-2014 11:26 PM
  6. fuzedkilla's Avatar
    I had the same stupid problem just take out the SD card in the back of the phone it worked for me
    04-26-2014 11:27 PM
  7. gnirvana's Avatar
    Hitting it thrice on my palm worked. It's working fine now, crazy **** man. VOODOO
    04-30-2014 06:09 AM
  8. Ahmed Shamsuddin's Avatar
    suddenly from this morning slide bar for Wifi stays grey and cannot turn on. I have a galaxy note and had no issue for Wifi until this morning...
    wifi fixer doesn't work.
    06-13-2014 06:12 PM
  9. monty6630's Avatar
    Hey all,
    After more than a week with NO WIFI, i have finally figured it out.
    Here are the detailed.
    ISSUE: After OTA update of 4.4.3 on new nexus 5, the phone was rebooted automatically and after reboot WIFI button was greyed out. It only showed "TURNING ON".
    FAILED SOLUTION ATTEMPTS: Following step DID NOT HELP
    1. Factory reset
    2. Battery drain and recharge after full drain
    3. Power off for few hours and restart
    4. Whacking the set on palm (yes, whacking, it was a recommended solution on a thread)
    5. Opened the handset and checked all the hardware link, every thing was fine
    6. Bootloader unlock, recovery installation (TWRP), downgrade to 4.4.2 (downloaded from google's web page)
    7. Downgrade to 4.4
    8. OTA update from down graded firmware
    9. Sideloading the 4.4.3 update on firmware 4.4.2
    10. Rooting, and installation of custom ROM (slimKat, Cynaogen mod)
    11. Installation of custom kernel (linaro)
    12. Flashing of 4.4.2 & 4.4 Radio/Boot images on stock rom of 4.4.3
    13. Clean install of 4.4.3 (removing everything from phone except recovery)
    14. *#*#4636#*#*, goto wifi and restart.
    15. *#*#4636#*#*, wifi state shown "UN-INITIALIZED"
    Actual Solution that worked
    ***** Install Paranoid Android ROM on rooted Nexus 5. The issue is with Kernel , which control the HW/OS communication. Apparently Kernel of this ROM removed the issue (but installation of SlimKat/CyanogenMod/Custom Kernel).
    I then restored the backup of stock 4.4.3 from recovery and did a factory reset. Wifi & every thing else works fine now *****
    06-18-2014 05:07 AM
  10. Larissa Harris1's Avatar
    This worked. Thank you!
    07-09-2014 09:20 PM
  11. peterjohn21's Avatar
    My wifi didn't turn on please help me ??
    07-27-2014 12:06 AM
  12. Maria Diminutto's Avatar
    Okay My WiFi won't turn on, I've Tried factory resetting my phone and everything, I've even tried just giving It a whack but It won't turn on, my device is a Samsung Galaxy Ace II x, and I would like to get this problem fixed because my phoneIis not currently hooked up and, I would like to be able to access the internet so I can contact people. If anyone can find the solution to my problem please let me know?
    Thank You!
    08-23-2014 07:43 PM
  13. Jaydhie Garcia's Avatar
    10-04-2014 09:42 AM
  14. ipisces's Avatar
    Omg, this actually worked! The most simple fix was the most effective. Thanks for sharing, I now have my WiFi back
    10-12-2014 05:33 AM
  15. falafeldiaper's Avatar
    I have a GAL 4 - Tmob. Same issue. And yes...smacking it with your hand works. Guess I'll take it apart and re-seat the wifi/BT ant link.
    Love technology...
    12-27-2014 01:44 PM
  16. An-An Gonzales's Avatar
    how hard i need to whack my monster tablet m7 7" gosh!.. pls help.. my tablet wont turn on the wifi..
    01-17-2015 06:03 PM
  17. An-An Gonzales's Avatar
    can you please help me too. my monster tablet m7 7" wont turn on the wifi.. i turn it on then go back to turn off.. i already whacked it but does worked.. please help..
    01-17-2015 06:10 PM
  18. savortheflesh's Avatar
    01-28-2015 09:49 PM
  19. savortheflesh's Avatar
    This helped!
    01-28-2015 09:52 PM
  20. sam vijay's Avatar
    tapping at the back of the phone does work
    07-17-2015 11:39 PM
  21. DrZardoz's Avatar
    OMG, whacking it worked! We call it "percussive maintenance" in the business. Yeah, the tablet is aging (Idea USA CT920) and it was cheap. Ran good for 2 years. Of course whacking fixes are never a good sign! Thanks bro, I can stop messing with it now that I know it is a mechanical issue and not software.
    10-27-2015 12:51 AM
  22. JessSeptic's Avatar
    I tried whacking my Moto E phone against my palm and leg multiple times and the wifi still wont turn on..? Am I just not hitting it hard enough? Its been saying "Turning Wifi On..." for the past 2-4 hours and it still hasn't turned on. This only happens when my phone dies or I turn it off and start it back up. I'm getting really frustrated that nothing is working :/
    01-17-2016 03:08 PM
  23. 123rhonda's Avatar
    Turns on an BAc k off
    08-27-2016 12:37 AM
  24. crazy2412's Avatar
    Created account just to say Thanks. however i have a rooted phone, it turn off and on again and again. The WACKing worked for me. Now i have a permanent troubleshooting method.
    10-26-2016 04:32 AM
  25. melinda Legerski's Avatar
    Try charging it over 30%. My husband has an S4. He started having this issue yesterday so I've been on these forums a ton in the last 48 hours. He tried some hack from a video typed into the dialpad and then he yanked the battery out without shutting down the phone and his wifi was restored. Overnight his phone died and there was no connectivity again once he got it turned on again UNTIL it hit 30%. It's been fine ever since as long as the automatic power save from dipping too low doesn't engage.
    04-20-2017 07:06 PM
50 12
  1. my captivate wont turn on and says usb connected
    By jjnewb in forum T-Mobile Vibrant
    Last Post: 08-15-2010, 09:14 AM
  2. Evo wont turn on
    By osakran in forum HTC EVO 4G
    Last Post: 06-25-2010, 07:14 PM
  3. phone wont turn on
    By jnadelman in forum HTC EVO 4G
    Last Post: 06-22-2010, 06:49 AM
  4. phone wont turn on!
    By jd in forum Motorola Cliq and Dext
    Last Post: 06-12-2010, 01:41 PM
