Ok so I tried to turn on my WiFi in the settings and it would say turning on then stop and say error. I've restarted my phone, done a factory reset and even used a WiFi fixing app. Anyone know how I can fix this?
Hey all,
After more than a week with NO WIFI, i have finally figured it out.
Here are the detailed.
ISSUE: After OTA update of 4.4.3 on new nexus 5, the phone was rebooted automatically and after reboot WIFI button was greyed out. It only showed "TURNING ON".
FAILED SOLUTION ATTEMPTS: Following step DID NOT HELP
1. Factory reset
2. Battery drain and recharge after full drain
3. Power off for few hours and restart
4. Whacking the set on palm (yes, whacking, it was a recommended solution on a thread)
5. Opened the handset and checked all the hardware link, every thing was fine
6. Bootloader unlock, recovery installation (TWRP), downgrade to 4.4.2 (downloaded from google's web page)
7. Downgrade to 4.4
8. OTA update from down graded firmware
9. Sideloading the 4.4.3 update on firmware 4.4.2
10. Rooting, and installation of custom ROM (slimKat, Cynaogen mod)
11. Installation of custom kernel (linaro)
12. Flashing of 4.4.2 & 4.4 Radio/Boot images on stock rom of 4.4.3
13. Clean install of 4.4.3 (removing everything from phone except recovery)
14. *#*#4636#*#*, goto wifi and restart.
15. *#*#4636#*#*, wifi state shown "UN-INITIALIZED"
Actual Solution that worked
***** Install Paranoid Android ROM on rooted Nexus 5. The issue is with Kernel , which control the HW/OS communication. Apparently Kernel of this ROM removed the issue (but installation of SlimKat/CyanogenMod/Custom Kernel).
I then restored the backup of stock 4.4.3 from recovery and did a factory reset. Wifi & every thing else works fine now *****
