Results 1 to 5 of 5
    Default wifi wont turn on
    Ok so I tried to turn on my WiFi in the settings and it would say turning on then stop and say error. I've restarted my phone, done a factory reset and even used a WiFi fixing app. Anyone know how I can fix this?
  2. #2
    lynnneil's Avatar
    Posts
    Global Posts
    99 Global Posts
    Default Re: wifi wont turn on
    Install the app called "Wifi fixer" through the cellular data. This app will solve all the issues of the wifi connections.
  3. #3
    I have a problem too involving the wifi. My wifi win't turn on. It will just say wifi turning on, but then it will go back to wifi off. And I don't have a cellular data plan. Can anyone help me with this problem?
  4. #4
    suddenly from this morning slide bar for Wifi stays grey and cannot turn on. I have a galaxy note and had no issue for Wifi until this morning...
    wifi fixer doesn't work.
  5. #5
    I have droid razr m (rooted) version 4.0.4 .... having few issues if anyone could explain to me would be great.
    1...since rooted, phone will not update to 4.1.2 when applying update phone will give verification error... think maybe if i unroot then try. but havent been able to unroot yet.
    2....Wifi has for some reason turned itself off and will not turn back on, tried several times, also tried (factory reset) no results,
    anyone who may have a solution please let me know... thanks for your time.
    (Unrooted) then factory reset... did not help with update or fixing Wi-Fi... out of ideas.
  1. my captivate wont turn on and says usb connected
    By jjnewb in forum T-Mobile Vibrant
    Last Post: 08-15-2010, 09:14 AM
  2. Evo wont turn on
    By osakran in forum HTC EVO 4G
    Last Post: 06-25-2010, 07:14 PM
  3. phone wont turn on
    By jnadelman in forum HTC EVO 4G
    Last Post: 06-22-2010, 06:49 AM
  4. phone wont turn on!
    By jd in forum Motorola Cliq and Dext
    Last Post: 06-12-2010, 01:41 PM
