1. Phil Nickinson's Avatar
    Compiled every Motorola Droid Pro help video in one place. Here's where to find them.
    http://www.androidcentral.com/motoro...ro-help-videos
    11-06-2010 10:40 PM
  2. Phil Nickinson's Avatar
    Find something cool (or important)? List it here.
    Enable screen rotation: Menu>Settings>Display>Auto-rotate screen (checked)
    Rename profiles: Menu>Profiles>Menu>Rename
    Remap side button: Menu>Settings>Applications>Quick Launch (remap side key)
    11-18-2010 01:51 PM
  3. jb20's Avatar
    After opening the gmail application you can do the following on the key pad:
    C- Compose an email
    R- Reply to an email
    A- Reply to all
    Very similar to a blackberry.
    Also I use screen mode widget and have the settings set to disable the lock and all you have to do is touch any key to wake the phone.
    11-20-2010 05:57 PM
  4. jb20's Avatar
    Another tip for those who just want to you the keyboard to quick search a contact rather than using the contact search widget.
    Go into seach application( either the magnify glass icon or google search widget)
    Hit menu-
    Hit search settings
    Hit-searchable items, from here just leave just checked contacts.
    Close the program and return home. Now type in any name or letters on your keyboard and you should see your contacts should show up
    Note if you want to do a google search just go into the browser application.
    11-21-2010 06:56 AM
  5. milominderbinde's Avatar
    I will add any new tips I can to the Getting Started with Android - Tips and Tricks.
    11-21-2010 06:20 PM
  6. google123's Avatar
    UNIVERSAL INBOX ON THE HOMESCREEN.....
    I found a way using LauncherPro.
    1. Install LauncherPro (free version available in the market)
    2. With LauncherPro running.....
    3. Press/hold on homescreen...
    4. Choose shortcuts
    5. Choose Activities (has the yellow LauncherPro icon next to it)
    6. When the activities list opens, scroll all the way down to Universal Inbox and click it...
    7. A sub list will open showing Universal Inbox and Edit Universal Inbox.
    8. Choose Universal Inbox
    9. You have now placed a shortcut that will open the Universal Inbox on your homescreen.
    10.
    I was able to do this just now but if you have just installed LauncherPro, you may need to check the options if some of these steps don't match on your device. Good Luck
    11-26-2010 04:06 PM
  7. supermiah's Avatar
    Good information...
    11-30-2010 02:24 PM
  8. kyleward27's Avatar
    UNIVERSAL INBOX
    How do I make my universal inbox read my email too?
    12-01-2010 09:36 PM
  9. CSI Guy's Avatar
    Thanks Phil for putting up those videos.
    12-02-2010 02:25 PM
  10. Eighty_3#AC's Avatar
    It is greatly appreciated.
    12-02-2010 04:07 PM
  11. flash24's Avatar
    thanks!
    12-03-2010 06:11 AM
  12. Dunc1000's Avatar
    Thanks for the videos. Very helpful. I would note that email search does not seem to work when accessing email through the universal inbox.
    12-31-2010 11:02 AM
