Results 1 to 5 of 5
    Supermanwoot's Avatar
    Posts
    Global Posts
    79 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default ChompSMS on droid pro
    So my chomp doesnt show my contact pictures even when the option is selected, it just shows the questionmark default outline picture.
    Anyone else know of integration issues with 2.2 and chomp or what?
    And is there something I have to do to make it my default sms service?
    Sent from my DROID PRO
  2. #2
    theMehi's Avatar
    Posts
    Global Posts
    22 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    did you ever find a solution for this? i have the same prob with Chompsms , although the default text app shows all display pics.
  3. #3
    Eighty_3#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I haven't had the need for an alternative SMS client.
  4. #4
    brina042's Avatar
    Posts
    Global Posts
    170 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I use the stock messaging app and use "sms popup" by Adam K to change the notification sound and LED color for different contacts
  5. #5
    google123's Avatar
    Posts
    Global Posts
    506 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    My installation of ChompSMS shows contact pictures just fine.....
