Results 1 to 7 of 7
    Default pro gets hot!
    Why is the back of the phone hotter than you know what?
  2. #2
    njdevs96's Avatar
    Posts
    Global Posts
    45 Global Posts
    Default
    Mine did too at first, but then I discovered that it came setup for "global", once I switched it to "cdma" I haven't noticed it getting hot anymore??
    Default
    Yeah I switched that as well. Was wondering if that was the problem. Well see.
  4. #4
    Default
    Must be because mine is ice cold.
  5. #5
    Default
    IIt also gets super hot if running any flash in the browser.
  6. #6
    Default
    Mine gets a little warm if I'm messing around with it for more than 30 minutes or so, but I wouldn't consider it hot by any means. My Droid1 was twice as hot as this one all the time.
  7. #7
    flash24's Avatar
    Posts
    Global Posts
    779 Global Posts
    Default
    Download SetCPU and lower it to 600 mhz if not in use.
    Thanked by:
