1. jpcalhoun's Avatar
    Anyone using LauncherPro on the Droid Pro...and do you recommend? Please contrast the between LauncherPro and the launcher that comes with the Pro.
    12-19-2010 09:12 AM
  2. Eighty_3#AC's Avatar
    I am using LauncherPro and am much happier with it than using the stock launcher. It is more customizable and runs a lot smoother You can also set it to have 7 screens, whereas the stock only has 5. However, if you want to resize widgets, you will have to get the paid version for $1.99(?).
    12-19-2010 10:14 AM
  3. google123's Avatar
    I have been using LauncherPro for a while now. I like that I can have several docks' worth of customizable icons to scroll through, each with a click and a swype up function. I like the multiple screens, resizeable widgets, ability to hide apps in the app drawer, hide the notication bar, and the overall performance. I purchased the Plus version to support the developer and use the calender widget as well. Very happy with all the updates no problems whatsoever.
    12-19-2010 04:47 PM
  4. PHaim's Avatar
    I have the paid version, I think it's definitely better than stock although I also think that it's basically a weak version of HTC's Sense UI and wish I had that instead. There's one or two of the Motorola widgets that I kind of miss (I like their wifi/blutooth/etc buttons) and you give those up to use LauncherPro
    12-19-2010 07:15 PM
  5. google123's Avatar
    Some of the Motorola widgets still work under LauncherPro. I have been using WiFi, BT, and Airplane Mode no problem.
    12-19-2010 11:37 PM
  6. macstibs's Avatar
    I've been using ADW.launcher and am pretty happy about it.
    12-21-2010 08:01 AM
  7. Eighty_3#AC's Avatar
    I've tried ADW, but prefer LauncherPro. Have you had a chance to try LauncherPro?
    12-21-2010 01:44 PM
  8. macstibs's Avatar
    There were a few things that I preferred on ADW.
    1. You can customize your drawer pages somewhat using "categories"
    2. You can resize widgets without having to buy the premium version.
    3. Themes give me the ability to change the look of the interface.
    Coming from a Galaxy S, these made me more "comfortable" than LauncherPro.
    12-21-2010 08:46 PM
  9. Eighty_3#AC's Avatar
    Thanks for your response. Obviously, I didn't "explore" this launcher very well. :o I will give it another try, when I get the chance.
    12-22-2010 12:05 AM
