1. pilotrose's Avatar
    So I acquired what is apparently a Droid Pro SBF file for Verizon, two PRL files, and the SOURCE code for the Droid Pro.
    I do not know if these files are the right ones, maybe someone else would have a better idea. So far, I have gotten my bricked Droid Pro connected to RSD Lite 4.9 by holding down the Volume UP and DOWN keys when turning on the phone, then connecting it to the computer.
    I load the SBF, and begin the process, then usually after it builds the image, there is an error on the droid:
    Critical Error:
    FEBE 0047
    And RSD Lite says the flashing failed and Error sending JUMP connection, along with a lot more numbers and non-sense.
    The size of the SBF is 444 MB, which is much larger than normal, and the name is: VRZ_A957_2.4.5_1FF_01.sbf
    The SBF is split into a 3 piece .rar file which may be corrupting it.
    The links to all of what I have will be shared shortly by another person who I have been trying to work on this with.
    Any help or ideas would be greatly appreciated. Merry Xmas.
    12-25-2010 05:39 AM
  2. mustahaque's Avatar
    File Properties:
    Filename: VRZ_A957_2.4.5_1FF_01.sbf
    Creation Date: 09/14/2010 17:16:26
    File size: 455655933
    RAM DL Version: N / A
    Bootloader Version: N / A
    Platform: 4G OMAP
    HAB Type: Signed Production
    12-25-2010 07:14 AM
  3. mahst687's Avatar
    I know this may help little but I do remember at least with the dx that I had to put the file in my base c:/ operating drive and also rename it using a certain number of characters for the file name based off of something in the error log after a failed sbf attempt... I think there is a forum post somewhere about it or something.... this at least what is needed for windows 7 to be able to sbf my old dx...
    at least we got some type of sbf.... this way I can upgrade soon since because I deodexed my dpro the update has not worked plus I think also because of it being clockwork modded...
    Here's to you making it a very merry xmas for all dpro users... now everything seems to be falling into place for romming to begin!!
    If and when we get this working... I will probably post base stock clockwork backups for the dpro: without update, with update and deodex with update to help others with quicker recoveries
    12-26-2010 10:17 AM
  4. mustahaque's Avatar
    Thanks for the info. We are waiting for our source to provide us with the un archived sbf. Then we'll share the possible Source Code and the sbf with the community.
    12-26-2010 12:15 PM
  5. pilotrose's Avatar
    Free File Hosting Made Simple - MediaFire
    Here is the source link.
    Please post results and error codes you experience here.
    12-27-2010 01:50 AM
  6. pilotrose's Avatar
    If anyone is able to, please connect your Droid Pro to RSD Lite 4.9 in download mode. (turn off phone, hold the volume down button, then connect the usb cord to the phone, release the volume down button after a few seconds)
    Please indicate what RSD Lite displays for your phone, or better yet, provide a screen shot. Thank you in advance.
    I am currently thinking that the current version of RSD Lite available to us isn't able to access what it needs to on the phone and/or the SBF file given to us isn't correct.
    12-28-2010 12:09 AM
  7. pilotrose's Avatar
    Here is the link to the Droid Pro SBF file that I received. Enjoy!
    To flash, download RSD Lite 4.9, the latest Motorola USB Drivers, and start the phones boot loader by turning off the phone, and holding the volume up and down buttons while connecting the phone to your computer.
    Load the SBF in RSD Lite and flash it, should take less than 10 minutes.
    01-02-2011 05:42 AM
  8. terpitude71's Avatar
    wouldnt be a bad idea if a few of you guys could mirror this as well, just in case
    01-03-2011 06:54 PM
  9. google123's Avatar
    01-04-2011 11:38 PM
  10. Phill_UK's Avatar
    Thanks for posting the mirror Google123, but I think you've missed something out of the zip...
    I was unable to flash using your sbf, and had to use the original TBH link.
    Did you include the source files?
    01-08-2011 08:20 AM
  11. fish111fish111's Avatar
    Very nice man! Can't wait.
    03-29-2011 05:24 PM
  12. Burkett1983's Avatar
    Thanks for the Post I was able to successfully put the SBF on my droid pro!
    04-26-2011 10:23 AM
  13. Zottig's Avatar
    Critical Error:
    FEBE 0047
    This is probably a long shot, but does anyone still have that VRZ_A957_2.4.5_1FF_01.sbf file? The A957 is the Droid2 R2D2 (not the Droid Pro as some early speculation seemed to suggest) and if that's an SBF for that phone I know a number of people who would be thrilled to be able to SBF back to stock with that file if indeed it is for the R2D2.
    Ben
    chasehammer likes this.
    09-15-2011 02:31 PM
  14. spencettu's Avatar
    Another person that needs the original VRZ_A957_2.4.5_1FF_01.sbf. If you have it please upload it somewhere . It would be greatly appreciated. The original links are dead. Need to get back to stock so I can get gingerbread OTA. Thanks.
    09-15-2011 10:56 PM
