R reykjavik Well-known member Nov 19, 2010 85 1 0 Visit site Jan 9, 2011 #1 Anyone know if there is one yet? If so, anyone try it?
T terpitude71 Retired Moderator Dec 9, 2009 1,706 203 0 Visit site Jan 9, 2011 #2 highly doubtful it will happen, considering they never made a version for the X or D2
igotsanevo4g Retired Moderator Jul 31, 2010 3,396 601 113 Visit site Jan 10, 2011 #3 Locked bootloader = Not possible because you cant change the kernel.
F flash24 Active member May 14, 2010 28 2 0 Visit site Jan 13, 2011 #4 This makes me sad Still waiting for a fixed version of Fission ROM Sent from my DROID PRO using Tapatalk
G google123 Well-known member Jul 12, 2010 100 6 0 Visit site Jan 27, 2011 #5 So locked bootloader just means no custom kernels but custom Roms are still ok???
Stang68 Well-known member Mar 15, 2010 2,270 99 0 Visit site Jan 27, 2011 #6 I'm waiting for ANY custom ROM for the Droid Pro.
B butler360 Well-known member Jan 27, 2011 45 2 0 Visit site Jul 8, 2011 #7 Gonna build cyanogenmod 7 for the pro - Droid Forum - Verizon Droid & the Motorola Droid Forum
S Spectacle.Guru New member Mar 11, 2012 2 0 0 Visit site Mar 11, 2012 #8 JackpotClavin has ported both CM7 and an alpha version of CM9 for the Droid Pro. I've run both with no problems and much better results than the stock ROMS. CM7 - [ROM] [NEW] Cyanogenmod 7 for the Gingerbread Kernel CM9 - [ROM] CM9 ICS For the Droid Pro
