Results 1 to 2 of 2
- 02-23-2011, 10:35 AM
Thread Author #1
Car/Laptop Charging
I can't seem to get my Droid Pro to charge from when either plugged into a laptop or on a generic car charger.
I does charge OK on the OEM wall charger.
It's not a cable issue.
Are the charging smarts in the wall charger that as needed for it to charge like some laptops use?
I'm assuming its to do with power limitation on a generic USB port?
Is there an app to convince it to to charge?
Will any Motorola Wall/Car charger work (like a regular droid one for example) ?
Thanks - 02-23-2011, 08:33 PM #2
Reply
