Results 1 to 25 of 25
    scarryman04's Avatar
    Posts
    ROM
    Jelly Bean/ Thors ICS
    Default Project Elite ROM
    I came across this ROM a few days ago and just flashed it last night, as soon as I did, I ran a Quadrant and scored a 1381!!! It is an amazing ROM, tons of features and seems super stable, I haven't had any problems with it at all. It uses the Slayher 1.1 Ghz kernel hence why it is so fast, but there is a internal governor so you can overclock and underclock from the ROM settings if you don't want it to run so high if you don't want it too...anyways thought I would share this ROM so here is the link...happy modding
    How to contact ROM Dev- Twitter: @actngrezy
    Thanked by:
  2. #2
    Default
    +1 just flashed a couple days ago. its amazing, extremely stable
    Posts
    ROM
    Default
    Project Elite V4.2 just released last night!!!!!!
    Link to website for download below!!!
  4. #4
    cmorty72#AC's Avatar
    The bending unit
    Posts
    ROM
    Stock (so far)
    Question Installed PEv4.2 won't let me into recovery!
    Been running PEv4 since it first came out... OUTSTANDING rom!!!
    I just switched over to PEv4.2 last night and been having problems ever since. Did a clean install via ROM Manager.. backed up and wiped... and now I can't get into recovery (wtf?).
    I've tried doing it manual (on/off + X), and through the reboot option, but to no avail.
    Does anyone have any other ideas that I should try in order to get into recovery?
    *Edit*
    Never mind.... I just fixed my own issue.
    ROM Manager wasn't giving me a valid recovery. Just had to keep pushing it through until it takes.
    Droid -{+_+}- Razr
    http://squintzy.mybrute.com
    Posts
    ROM
    Default
    Project Elite 4.3 (maybe) gingerbread ROM is in the works...no ETA on it tho.
  6. #6
    DeeMat's Avatar
    Posts
    Global Posts
    282 Global Posts
    Default
    I love this ROM. The team seems to take his time and think things through. They do not add stuff that negatively affects performance. Can't wait for the next version.
    Posts
    ROM
    Default
    OMG...PE V5 is going to be released sometime this week!!! The dev just posted a screenshot on twitter. It looks like he's not using a Slayher kernel this time...maybe one of his own.
    Thanked by:
  8. #8
    The bending unit
    Posts
    ROM
    Stock (so far)
    Thumbs up
    Quote Originally Posted by scarryman04 View Post
    This is great news!!
    Looking forward to it's release.
    Droid -{+_+}- Razr
    Posts
    ROM
    Default
    Yeah I'm pretty stoked about it...I might ditch CM7 for it!!!
  10. #10
    DeeMat's Avatar
    Posts
    Global Posts
    282 Global Posts
    Default
    PE past releases are super stable. Can't wait to see what he does with his GB release.
  11. Thread Author  Thread Author    #11
    Posts
    ROM
    Default
    He's been posting a lot of stuff on twitter lately making hints its really close to release!!!
  12. Thread Author  Thread Author    #12
    Posts
    ROM
    Default
    Project Elite V5 available now!!!!
  13. #13
    Effenhimer's Avatar
    Posts
    ROM
    Stock, (for now)
    Default
    Whoot!! Just flashed V5, lovin' the custom ROM again!!! Was on Pete's GB Vanilla Stock rom, worked PERFECT, but nothing flashy, just a straight GB build. I'll be watching for the BBGPA when he gets to it, but for now, I'm prolly gonna be using this one!
  14. #14
    Last Ride's Avatar
    Posts
    Global Posts
    262 Global Posts
    ROM
    4.2
    Default
    I flashed V5 yesterday, and so far I LOVE it. I was having problems with UD2.5, and even though my Quadrant score was about 100 lower with PE V5, the phone is running so much more smoothly. It looks clean, laid out well. It's given new life to my OG Droid. I will be using this one for a while.
  15. #15
    Default
    I'm afraid I haven't had much luck getting v5 to work today. My first attempt at installing it resulted in it getting stuck on the animation screen. After about 3 battery pulls, it finally came up and then stuck on the gmail login/sync for a while before rebooting over and over again into the boot animation. After another battery pull I managed to get through the setup and to a home screen, but then it got stuck trying to turn on WiFi and began rebooting itself.
    After that I restored to 4.5. I decided to give it another shot. This time it loaded up and got to setup on the first try. I got through setup with no problems, and even turned on WiFi with no problems. Then I hit the menu key, wanted to back out of the menu and hit home key and it stuck and rebooted. It came up ok. I went to the market to look at the apps downloading and it hung and force closed. Tried it again with the same result. I am now restoring back to 4.5 for now.
    I wonder if its default kernel isn't compatible with my Droid?
  16. #16
    MowDownJoe's Avatar
    Regular lawnmower man...
    Posts
    ROM
    Stock
    Default
    Going from CM6 to V5 of this is a breath of fresh air. Wow. Battery seems to drain much faster, though... I could go all day on CM6. In the 3 hours it took setting myself up, I found myself down to 20%. Admittedly, screen was on the whole time, but still...
    [Edit:] Flashed a different kernel. (Love how that's built in.) Pete's Low Voltage 1050MHz kernel seems to be more battery friendly than the stock 1100 MHz low voltage kernel.
    Edit 2: Just noticed there's no native Android tethering, like CM6 had. My Cr-48 is sad, now.
  17. #17
    luke31's Avatar
    Posts
    Global Posts
    493 Global Posts
    ROM
    AOKP JB Build 3
    Default
    Is this as stable as Pete's stock ROM?
    Droid DNA by HTC
    Nexus 7 16GB
  18. Thread Author  Thread Author    #18
    Posts
    ROM
    Default
    I haven't tried this yet...trying out Ultimate Droid 3.0...kinda buggy so I'm debating trying this one out or going back to CM7, any suggestions?
  19. Thread Author  Thread Author    #19
    Posts
    ROM
    Default
    Quote Originally Posted by Effenhimer View Post
    Yeah customs are where it's at!!! I don't even know why people are making a big deal about GPA...I had GB way before he released that lol
  20. #20
    ericdroid's Avatar
    Posts
    Global Posts
    32 Global Posts
    ROM
    Stock
    Default
    I just switched to this one from the CM7 nightlies, and so far I love it. It's not based on CM, though they do use a lot of code from it (and they're really good about acknowleging this).
    It's faster than CM7. That's partially due to a faster default kernel, but I think I'm gonna stick with this a little bit.
  21. #21
    Default
    Gave this another try today with the 5.1 download, and it just doesn't work with my Droid. I even followed the site's instructions for installing it instead of letting ROM Manager do it. I keep having the same issues with the phone randomly restarting over and over again. I'll wait for CM7 to be done. In the meantime the Froyo PE ROM still works great for me.
  22. #22
    Effenhimer's Avatar
    Posts
    ROM
    Stock, (for now)
    Default
    K, is anyone else having random problems with camera and overheating using the browser and things?
  23. #23
    Last Ride's Avatar
    Posts
    Global Posts
    262 Global Posts
    ROM
    4.2
    Default
    Can anyone recommend a good kernel for V5.0.2? I've been trying the slayher 1200, Pete's 1.05, and a couple others on the download part of this ROM. Right now, I'm using the 1100 SV because I was having issues with the LV kernels and signal strength (I work in the basement). The only problem now is it's KILLING my battery. Any recommendations? I love this ROM!
  24. Thread Author  Thread Author    #24
    Posts
    ROM
    Default
    If your going to use a standard voltage overclocked kernel its going to drain your battery really fast...find a 800Mhz SV kernel its still overclocked but will give you waaaay better battery than a 1.1Ghz kernel.
  25. #25
    Default
    I have had V5 since the day it was released. And it is pretty great. I flashed this after reading an article about it on droid life. I have the RZ low voltage 1100 kernel running with it. Its extremely smooth and fast. The only problem I ever have is my phone will randomly reboot. But it is not a big deal because it only takes like 10 seconds and its good to go again. But apart from that games are fast and smooth. scrolling is smooth and the UI is pretty epic in my opinion. + gingerbread is so much better then froyo. ohh and Battery life lasts about 10 hours or more with pretty heavy usage. As i text allot ,make phone calls, check my email, listen to music, play games, and use the web several times a day.
