This is my first custom ROM (CM 6), and I am running into more problems than any benefits I can see, and I am getting frustrated. I was rooted before, using Launcher Pro and all was going well, but I was afraid that the new OTA update coming would break my root, so I took the plunge and the flashing went fine, but I am not sure it was worth the effort:
First, I can't connect to any open wifi and, until I turned it off, it kept scanning, running my battery down.
Second, my Titanium has stopped working (did OK for a bit after the flash, then went *poof*). It can't find busybox, thinks the phone is not rooted. Going through the "Problems", uninstall, reinstall, etc, and nothing. Downloaded busybox installer and it said it can't install it.
Third, suddenly I can't get the stock messaging app from giving me pop-ups for text messages (I did get it to stop giving notifications in the taskbar by unchecking notifications, but this did not help with the pop-ups, even after a couple of reboots).
Fourth, I have gotten Launcher Pro force closes a few times, causing a redraw even though that problem had been solved before (and I have checked the appropriate box in LP and added the fix code in an terminal emulator).
Fifth, even with the wifi turned off, I am getting half the battery life as I did before with the stock ROM.
On the positive side, I have music controls in my lock screen and I have more space freed up in my internal storage (which is very helpful).
