Pre-Requisite: Your Droid must be at version 2.0.1
1. Download "Root my 201 Droid.zip" from here.
2. Extract and transfer update.zip, to your Droid's SD card, either via an SD card reader or USB.
3. Power down Droid.
4. Hold down the "X" key on the physical keyboard and do not let go.
5. Now press the power button while you continue to hold the X button.
6. When you see a triangle you can stop pressing the power and X button.
7. Now press the volume up button and do not let go.
8. Now press the camera button while you continue to press the volume up button, until you see a menu.
9. Using the directional pad on the physical keyboard, select the option to update using update.zip file.
10. Once the update is complete, select the option to reboot the phone.
Your phone is now rooted.
Many thanks to embeem, mjxg, & Cyanogen for your efforts in making rooting possible.
