Optimum WiFi is a blessing and a curse. If I save my login for it, when I drive it probably goes crazy. The handoffs have been great with the last DT1 update and now with the DT2, but it still is annoying when it interrupts gps to do so and I miss a turn lol.
Yea, you're probably spending more time on cell data than you think. I tried those cable WiFi's for a while, but had more trouble using them than it was worth. If you want to run an experiment, go into your WiFi settings and see what the option for avoiding poor internet connection says. If the setting is ON, turn it OFF, and see what happens. It that setting is already OFF, then well, my theory is kind of busted.
I had it checked to avoid poor connections. This is an all of the sudden thing though. I've had the phone for two weeks and this is the first time cell standby is chunking down my battery life. Reset didn't work, might just factory reset for fun.
I returned my Turbo 2 the other night and got a new one - The reasons was for #1 the screen cover is so soft that I sliced it slightly and I wasn't aware it would do that but I was gonna be patient for that and maybe not but then Thurs I noticed I was down to 50% with hardly using the phone - put it on the charger it got really hot and hit 100% and restarted on its own. Once it came back up it corrupted two apps to the point I had to start uninstalling them just to figure out if an app was the problem. The corruption caused the screen to go blank and lock up. Needless to say I wasn't happy and there was no way I was gonna wait another day to go tell them and get it replaced as I was still within the 14 day time frame. I made it clear that the replacement started a new 14day period and that I would watch this one like a hawk.
Dam. That's a rare and unfortunate situation. Hope your new one works as intended.
I was having the same (or similar) problem. Phone reception in my house is 1x or 3g half the time. Phone was also awake 100% of the time. I'm not sure the issues were related, but I did a factory reset and only installed my most important apps and did them one at a time to see if I could isolate if it was a rogue app or if it was systemic.
I'm not sure what the culprit was, but so far so good. Phone is awake only when I want it awake...but phone radio is still lousy inside my house.
So, my phone is being held awake 100% of the time as well. Anybody have suggestions? I've already disabled most of the apps, are they any known culprits that come pre-installed?
