How to get Droid Turbo 2 to read incoming texts and respond to texts with voice commands?
sjcoelho
How to get Droid Turbo 2 to read incoming texts and respond to texts with voice commands? Thank you
I am trying to figure out how to set up the Droid to read texts while driving. I have the ability to talk to others through my bluetooth but cannot figure out how to get the text reading feature going? Please help. Thank you.
Ry
Moderator Captain
Trusted Member
Nov 16, 2010
17,654
214
Re: How to get Droid Turbo 2 to read incoming texts and respond to texts with voice commands? Thank
On Lollipop, go to the Assist portion of the Moto App.
Posted via the Android Central App on the Moto X Pure Edition
kmf1
1,250
37
48
Have you checked in the Moto app/Settings/Assist/Driving/Talk to me?
mikpaq
6
Okay, so I have always wanted this to work perfectly, however Moto voice is not that great when the car gets noisy. Here is how I setup my Droid to read texts out loud, and dictate texts and emails as well while driving.
1. Disable Moto voice. I have used this program on 2 different droids and it does not work well all the time. It's sporadic, I think it has to do with your network connection.
2. Install Dragon Mobile, once installed go to settings and under "in the car" turn "automatically start driver mode" to on. This app will read out your incoming texts. During the read out it will let you respond through it too. You don't want this program set to listen, just make the changes I mention before. Do not have anything set to on under "General". Under "My Assistant" you can select a voice and give them your own wake up phrase. Do not set any other options under "My assistant", they should all be off.
3. Setup Ok Google. This can be found under Settings" and "Language and Input". Under "Ok Google" Detection make sure "From the Google app" and "From any screen" are turned on. Under "Hands Free" select "for Bluetooth devices". Also under the main "Language & Inputs" settings allow "Bluetooth headset".
This setup allows me to initiate, texts and emails, as well as control the phone with OK Google. This is more efficient than moto voice since some commands require moto voice to trigger google search anyway. Ok google seems to work way better than moto voice too, far more consistent. When a text comes in however, Dragon Mobile will notify and display the text as well as read it out, gives option to reply and send immediately.
I have tried many setups and this one work best.
DOOG9517
202
10
I use the app Agent. It's like Moto assist, except that it actually works for me.
anon(5881519)
3
I would like it if the Moto app would let you specify which Bluetooth connections to recognize as a vehicle. It says it will learn it automatically over time, but it has been a couple months now and it hasn't learned it. Why can't you just tell it which one is your car?
I have tried Drive Mode and Dragon Mobile. I like the way Moto works the best. Too bad it doesn't always work. The only way it recognizes driving is if you leave GPS on all the time.
Moto0685
91
I tried dragon I liked it but it is a battery sucker to say the least
wyseguy77
287
28
My T2 goes into drive mode as soon as it connects to my stereo in my truck and my car before I start driving.
ColinAlbright
7
This gent is right.. I have always used my Windows Mobile phone which interfaces perfectly with my Vauxhall Insignia, but of all the apps on Android that I have ever tried this seems to be the only one that allows me to get texts read back to me while driving and I can then do speech to text to respond.., and it works!, just like my Windows Phone always has.. So far, so good!
mlarson69
To which app are you referring? I too have a Windows Phone and find it necessary to be able to receive and reply to text messages while driving. As Microsoft has now announced that they are ending Windows Phone and my Ativ SE is getting rather old, I would like to find a good Android replacement phone. I realize this thread is a bit old but this is the most helpful one that I have found so far.
Zorro1
710
10
Waiting....mine used to read texts very nicely, and a couple updates back, just stopped. Now, all I get is a ding and a message that it can't....which isn't real helpful. I've checked all the settings as suggested.....
w8wca
