Lucy Davies
Lithium ion batteries are generally designed to charge in a temperature range up to about about 45 degrees C with no problem at all. That's about 113 degrees F, and as a matter of fact, Lithium Ion batteries have a current safety cutoff at 90 degrees C (194 degrees F). You're nowhere near a dangerous range, and it sounds like your battery is actually staying within the "ideal" charging temperature range. For more on Lithium Ion safety considerations, see:
Lithium-ion Safety Concerns – Battery University
OK cool. Thank you.
