Hi all, I recently purchased a T2 from Swappa, and loved it until about a week ago.
Seemingly out of the blue (started around noon on Saturday), the phone started rapidly draining battery. I am getting approximately 2.5-3 hours from a full charge, even when the phone sits idle on my desk. The phone also heats up to 100-110*f on the rear of the device while this is occurring. Turbopower charging is extremely slow due to the fact that the phone is using power almost as fast as it's charging.
Power cycling the phone has no effect. The only thing I have found that does help is turning on Airplane Mode for about 15 minutes, then switching it off. Once I do this, the battery life will return to normal, but out of the blue, the device will start heating up and chomping battery again.
The main power hog appears to be Google Services. Before you ask, I've cleared the cache and data for Google Services, Google Play Store, and Google Services Framework. I also performed a factory reset on the device on Monday night, and it didn't help matters at all. The only way to improve it is to enable and later disable Airplane Mode.
Does anyone have a suggestion on how to alleviate the issue? I lean heavily on my phone for work, and this makes it pretty difficult.
Here's a link to an imgur gallery of a few screencaptures: Droid Turbo Battery Issues - Album on Imgur
