I have a Turbo 2, and am having some issues with Turbo charging it. Recently, when I hook it to the factory supplied Turbo charger, sometimes it will display that it's slow charging.
Recently, I put it on the charger before I went to bed, and woke up the next morning to a dead phone. I'm positive that it showed that it was Turbo charging when I headed for bed.
When I found out it was dead, I unplugged it, left it for a bit; plugged it in and left charging for a while, and it was fine.
Other times, it will say that it's Turbo charging, and it seems to be. It's confusing why it doesn't seem to be getting the right amount of power using a factory charger.
I do run a VPN most of the time, but find it difficult to believe that it would pull the battery down that far when using a factory charger.
The phone is on version 24.14.16.en.us, if it's helpful for anyone else. I think it had one or two issues before the update, but it's gotten more prevalent since the update (June 29).
I'd like to avoid a factory reset, if possible. You never can seem to get things quite the way they were before the reset, it seems.
What am I missing, folks? If anyone has any ideas on how to fix this issue, I'm open to them.
