Restart takes 20℅ of battery!
Does the battery behave strangely in general? If so, I'd guess it's starting to fail.
That's a loaded question LOL unfortunately I purchased this phone based on the advertisements and rave reviews of it being a 48 hr battery......I'm lucky if I get 10 hours with NO MORE than 3 hours of on screen time......pitiful.
OP, I would suggest either buying a new battery or switching your device to a different model if you can. That kind of battery behaviour is not normal. I am sorry you are going through this!
If possible, give us a better idea of your battery stats by showing us some screenshots. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
Ok will do thanks!
Marabishi
