JIH2009
No, the stock camera is Moto Camera.
Sent Turbo-fast from my bulletproof 64GB Droid Turbo
Is one better vs the other?
Sorry to hear this. Mine is good.
The issue with a comment like this is that you expect different things from your phone than he does. The camera is perfectly fine on the Turbo for what I need it for. The pictures are very clear and good detail. The battery life is superb, operating system is lightning fast, voice recognition and other things work great.I have little doubt that it is the same as mine. I know you can't find one negative thing about this phone, but come on already.
Again, just because you find faults doesn't mean he has to have found faults with the phone.
Sent from my Motorola Droid Turbo
I saw the post although it was a quick look. I thought FireDogee was just making a suggestion just in case it solved an issue. Maybe he said it fixed his but I don't recall seeing that.EngineerGuy is not necessarily finding fault. He is contesting the idea that when FireDogee did the software update his camera got faster picture taking times whereas EngineerGuy's did not.
EngineerGuy, I've noticed with my old Moto that the shutter speed varies with the amount of light. That is, more light, faster shutter. I definitely have experienced the phenomena of snapping the picture and capturing an image a split second later. It sucks.
I'm not experiencing the other problems you are. Sorry.
I guess you have a "special" phone that nobody else does...
And FWIW, I never said it was a problem but rather agreed with others who have said that the capture was a bit on the slow side and that the magical software update didn't matter...as it didn't matter with anyone's phone, including yours.
"A bit on the slow side" is a bit generous.
I'm sorry you're so angry.
I'm not angry, just calling it like it is. Wish more would do the same instead of becoming so emotionally invested in a device that they cannot.
Just for everyone but one person...
My device also takes instantaneous photos. However when I have HDR/HDR auto on it takes longer to process the image. Seriously. Maybe my device was blessed by a Wizard before it was shipped to the local Verizon store.
