Motorola Droid Turbo: Screenshots & Homescreens
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,958
2,752
Got a cool homescreen or screenshot to share from your Motorola Droid Turbo? This is the place to show them off .
Have fun!
Re: Motorola Droid Turbo : Screenshots & Homescreens
here is my screen shot, this is a live wall paper, the flag blows in the wind and snow is falling
As you can see I went very utilitarian on color and overall tone -- metal/industrial -- and I still have lot's to add, but that will happen in short bursts over the next several days. All of the icons are folders with the obvious exception of the bottom row. I only use folders on my home screen. I usually use a live wall paper, but haven't found one that matches the Ballistic Nylon personality of the Turbo, so it's this for now.
Apex launcher, HD Widgets for the Time widget. I liked the Moto Widget, but not enough to keep it.
Edit: Finally "completed" my app installs and screen configurations. Also found a nice live wallpaper I like -- rotating gears that have a 3D aspect when you tilt the phone.Everything on the home screen is a folder, everything else is an application or widget.
How did you get the snow and wind to do that?
Live wall papers are animated. You can install static wall paper or live wall paper. Use "live" when searching in the app store for the animated wall papers.
Where did you find the icons for the folders?
its a live wall paper, its the NFL live wall paper by cellfish studios
Second try at uploading to the forum. Didn't mind the command widget, but wanted the new phone to look like the last. I use Fancy Widgets and found one with a translucent quality like the Google bar.
edison
Using ADW ex launcher With Cobalt Icon pac.
Pretty basic. Really loving this phone
I see you have the TeslaLED app. I couldn't get it to work on my Turbo.
It's working fine . Just tested it after reading your post . Try again I guess .
Nope still not working correctly. Doesn't turn on when entering app and doesn't until I exit the app. Will continue with one of my other flashlight apps as they turn on when starting the app. Thanks though.
Simple homescreen, but the QHD is super sharp. Love it.
My home screen.. Nexus Inspired..
Here's mine. Very simple, using TSF Shell Launcher, Ghost Theme, and the Vivid V2 icon pack. All of my most used apps are in the folders in the dock, accessible by swiping up through the folder and in the hidden menu on the left, which appears when I hit the back button.
Using Nova Launcher, a lot of gesture controls set in.
Mdean2030
