So you got your new Droid Turbo and you have found a bug, quirk or problem with it. Go ahead and share and try to be as descriptive as possible w/screenshots to help others out in identifying and possibly coming up with a solution.
Just picked up my turbo Thanks!
Also, how do I take a screen shot?
Any other hidden tricks or features with this phone?
Yes that is how you take a screen shot with the turbo.
The only thing I have found is when you push the home button while in an app it goes back to the previous screen and you have to push again to get to home screen. I also can't find HD calling that is supposed to be on the phone. I had it working on the MAXX>
I think you can share your "Me" contact info with others as a contact card. It may also effect the picture that appears on other's phones when you use certain messaging or texting services. Maybe.Thanks, Deron. Seems strange to be setting up a full contact for myself on my own phone. And what's the value in having my contact be available from that menu anyway? Seems like misuse of space. But I did do it and now my pic is there, so thanks.
For the corporate email, if you reply all, it includes me as a recipient. Unless I want to receive my own email, I have to manually delete my email address. A little annoying, but nothing catastrophic.
Mine did the same thing last night. I ended up exiting the app and going into it again. It then told me that since it was a new device they were suspending my Share card, and gave me a link to the web page where I could re-activate it. After I did that, it took about ten minutes for the card to show up again in the Softcard Wallet app.I don't have any of the creaking issues...Mine is around SoftCard (ISIS).... It is stuck on reloading after I accept terms and enter a pin... Won't activate on the new phone, Tier 1 and 2 level support are clueless. Teir 2 has me on hold right now. When I said Soft Card, he thought I meant SIM card... yikes.... Needless to say may be a software thing, or a secure element issue... However, Google Wallet installed and set up n about 1 minute. Google Wallet FTW. lol
