" but it does slow to a normal charge once the battery gets to around 50% in the Turbo charger. I"
Not on mine ... it flies all the way to 100%. Where did you read that ?
Where did you get that information ?
If I use the 'Turbo' charger (not to be confused with the phone name) ... it charges from whatever starting % all the way to 100% ... which I have confirmed by looking at the charging rate in my battery apps. If it didn't, what would be the point of a Turbl charger at all? BTW ... they should have called it Speedo Charger lol.
Well ...my bad. I check the charging rate after it finished charging ... and sure enough ... it ramped up quickly from 41% to 78%, then tapered off the rate until 100%.
My turbo 2 the display stays on when I put it on a qi2 charge pad. I have to click power to sleep display is there a way to auto sleep display at night. I may have to Tasker this?
