Small, but real gap between the chin and buttons. Looks like a dust magnet.
Which version? I have the 64 BN and no gap??
Are you sure? I looked at several Droid Turbos and I could see the "gold" colored hardware piece on each one of them. Either way, it doesn't bother me but I feel its normal and I've seen it on Moto beforeFunny you say that, my 64 ballistic had the same thing. You could actually see a "gold" colored hardware piece through the crack. Swung by the Verizon store on the way home to see if it was normal. Needless to say they swapped it out for me. The new one has no gap at all.
Sent from my Motorola Droid Turbo
That works, lol. I'm going to stick with mine as it is since it seems normal to me. Maybe having no gap is a flaw!Positive. Honestly I could have lived with it I suppose, but the gap is non-existent on the device I'm now using
Difficult to know for sure. The demo Ballistic Nylon and Metalized Glass units had the gap as did the phone I bought. I find it difficult to believe its a flaw based on that but who knows. I have zero creaks and a solid performing phone so I'm happy.I think the gap could affect the water resistant nano coatings ability to protect the phone if internal parts are exposed. I would have exchanged mine too.
Sent Turbo-fast from my bulletproof 64GB Droid Turbo
I saw it today on two of the three 32gb display phones at the Verizon store, the only one without the gap was the red one. Kinda disturbing, it doesn't look right...like the fit is just a bit off. One of those things you can't unsee; it would drive me nuts.
Posted via the HTC One
