Njbrandon
Re: Possible solution to low Volume during Calls
Would turning up the voice and treble on the EQ raise the overall volume?
Is it likely the low ear piece volume is a low wattage issue rather than a software issue? Can't be fixed by a software update because there's just not enough power going to that driver?
It boggles my mind that phone manufacturers continually struggle with call volume. Is it really that hard to ensure the volume can reach an adequate level? Would anyone complain if the volume maxed out TOO loud? C'mon moto.
