Does anybody know how to initiate battery saver mode? See snapshot from moto care. Implies that there's some sort of setting, which I can't find access to.
Anybody know?
RussellYou can set the location to battery saving, but that's the only one im aware of.
While i use my phone way too much to get 48hrs of life, except maybe on my days off, i know it will get me through a very long day (18 -20hrs) and i dont mind charging it every day when i sleep.
Its still an awesome phone and last night i had it off the charger for 19 hrs with 5.57hrs of on screen time, and had right at an hour of phone calls. Not to mentioned i was on playing some videos and listening to music. when i plugged it in this morning battery was at 42 percent... So i can't complain
These are just individual tips, no battery saver mode I'm aware of. This might change when we get the Lollipop upgrade due to Googles project Volta and enhanced battery life features.
Sent Turbo-fast from my bulletproof 64GB Droid Turbo
go into settings -> display-> attentive display-> battery saver check
yeah that is true, what i do miss is smart actions that moto had on razr maxx hd. simple and effective
Yuppers, that's just for the attentive display function. The phone itself doesn't have battery saver mode like the Galaxy S5...Probably bc the Turbo doesn't need it LOL
Battery save mode isn't really a need thing -- It helps anyone when they need to crunch battery. Also the S5/Note can replace and remove so that helps .
Don't need to replace, remove, or save with this giant battery. Turbo FTW
It isn't like super bigger than my Note 4.. and once we are both low I can swap to 100% in about 20 seconds .. no charge time needed .
If it's so great then why are you all over the Turbo forum? Methinks you wants to be a Turbo owner... Precious
Na.. It would be hard to get a turbo on T-Mobile .
I go all over the forums.. I am not locked to one area .
It would be hard to get reception on Tmobile. TTFN
I guess we should have posted this earlier in the thread. Better late than never!
"Only applies to optimized Motorola devices with Qualcomm® Quick Charge™ 2.0 technology such as the new Moto X. Battery must be substantially depleted; charging rate slows as charging progresses. All battery life claims are approximate and based on an average mixed use profile that includes both usage and standby time. Actual battery performance will vary and depends on many factors including signal strength, network configuration, age of battery, operating temperature, features selected, device settings, and voice, data, and other application usage patterns."
From Motorola website in description for Turbo Charger.
