Re: WiFi and data usage concurrently?
Same problem here:
WiFi is enabled
WiFi is connected
Mobile Data is "on"
"Set mobile data limit" is selected
"Alert me about data usage" is selected
Set upper data limit to "45 MB" (I have 250MB plan per month. I've used droid phones for years, and always had a low data limit, so I'm accustomed to using just 5MB of data usage per day.)
Two strange things happen:
1. It appears that I'm connecting to the wifi from home. There is no change in the amount of data usage on my settings screen. I do not pass the 45MB limit that I've self imposed.
2. Verizon says that I'm using large amounts of data, and I've used over 160MB since I've had the phone for the past five days, though my phone screen says I haven't gone past 45 MB.
When I turn OFF the data while I'm at home, it appears that I actually am using the wifi and Verizon doesn't show that I'm using data. However, when I have the data turned ON at home, it neither uses the wifi, nor does it the Turbo device record the amount of data that I'm using.
