- Jun 6, 2013
- 38
- 0
- 0
Side by side, the S4 in any room has full bar strength, and next to it the Turbo, has one less bar, unless it is in the same room as the Nighthawk router. Turbo with and without a case has the same results. Is the S4 WiFi just better than the Turbo?
Thanks for your advanced tips.
