I like GSM Arena. They seem to take the most objective look at devices. They have standardized tests they use to realistically compare across devices. They certainly liked the Droid Turbo!
The Motorola Droid Turbo is anything but lacking in top shelf specs. As a matter of fact, the smartphone is arguably the best-equipped Android smartphone available at the moment - it blows competitors away with a combination of powerful internals, a humongous battery, and the sharpest display available at the moment.
The device's build is nothing short of extraordinary. Motorola Droid Turbo is superbly put together and ready to take on the rigors of daily life, regardless of the circumstances.
Overall, Motorola Droid Turbo did a stellar job in our benchmark tests. The handset packs plenty of oomph and will handle anything you throw at it without breaking a sweat.
The camera of the smartphone doesn't disappoint either. It isn't quite the best we have tested, but it isn't far off the top either - you will not be disappointed by the images and the videos you have captured with it.
Motorola Droid Turbo is a complete package - a no-compromise Android powerhouse that is fit to accommodate even the most discerning power user. The smartphone blends high performance hardware, innovative materials, and stellar battery endurance into a compact, superbly built package.
Motorola Droid Turbo review: Power robot - GSMArena.com
