SatStar1
Ahhhh! People...you are not alone. It's a bug I think associated with lollipop. I'm 100% sure a bug. I need my music to go steady for my workouts. I'm driven crazy everyday by my phone fighting with itself on volume. I have it wayyyyy worse than yall described. I have note 4 on att also. Whenever I plug in my headphines..the "Media" volume will pop up randomly on its own and cut itself down. I can show u videos. I went as far as to install a volume lock app as a work around. Guess what..it works **** now I see the phone fight with the app..Hahaha I need to do a vid. U will see phone cutting music down while app tries to Muscle it back to locked setting amount. This drives me SOOOOOOO crazy. I was ready to snap and bust the phone as I hear the volume going up and down constantly. I thought it was my Urban Armor gear case. But nope. Took it off and issue still remains. I thought it was certain songs only at first or maybe headphones...but now I realize it's a true bug that needs to be fixed asap. I'm huge on working out and I need the music to zone out. So picture me ready to crush phone in hands because it's throwing me off on my zoning out....Hahaha. so much so I'm considering switching to that big iPhone like my note. But I don't know if they let u install the music to phone from Google. Not trying to stream constantly. Have a 64gb Samsung high speed card in the Note 4. Plus it came with 32gb internal. Alot is my music. I need this volume working right. Now I see why I'm missing calls and stuff also. The other things noticed are correcr. I'm experiencing them all and what I described.
I'm on Note 4 latest att lollipop update. I hate this lollipop bull. Lol smh I told my dad this update won't ish...lol now I'm dealing with all these new bugs. Just give me my kit kat bar back. I like the chocolatw..haha. please help! Sorry for any typos or whatever. Writing this like I'm texting.
If you're plugging something in to the headset jack on your phone then I'm fairly certain this is caused by the plug you're using. The jack on your phone also has a mic connection that is being shorted out by your stereo mini plug. Count the number of rings on the plug, most likely there are 3 connection rings (the tip plus 2 actual rings). One connection is the "shielding" or "common ground". Basically the "-" terminal for both Left & Right. The second connection is the positive "+" for the Left and the third connection is the positive "+" for the Right. The plug you should be using has at least one more connection and that is the positive "+" for the mic. Most smartphone headsets also have a Volume +Up and a Volume -Down that use the positive "+" connections is different combinations to signal the smartphone to increase or decrease the volume. Because your plug does not have a connection ring for the mic "+" and it's being shorted out inside the jack creating the same signal that tells the phone to decrease the volume.
SOLUTION: purchase a headset y-splitter that plugs into the smartphone jack and has two jacks; one for stereo headphones and the other for a mic.
Be careful, there are 2 types of headset y-splitters but only one will work. The other splitter, the one you DO NOT WANT, has 1 plug that splits to give you two headset jacks. Hope this helps...
