This is the message I get when I'm on a call and open the stock SMS program. I mentioned this in a thread about VoLTE and thought I was told text does not use data, and as such ths should not be a problem. What am I missing?
[url]http://i3.photobucket.com/albums/y61/hal1/Screenshot_2014-11-23-08-11-23_zpse5d9993b.png[/URL]
Got that message as soon as I tapped on the messaging app while on the phone.Were you just sending normal SMS messages? Or was this a group message and/or a photo ?
Yes, you can. That's just a popup that will come on anytime an app that has access to the internet is opened while on a call. Texting will go through fine...only MMS is still handled on the network so it cannot send nor receive MMS while you're on a call (even on WiFi). I am desperately awaiting VoLTE, those popups on almost every app are extremely annoying lol.
Posted via the Android Central App - Moto X (2nd Gen)
It seems you're right, kind of. I can write a message but it doesn't seem to send until after I end the call.
I use Verizon messages and never get this pop up. It can also send and receive over WiFi if you're out of cell range.
Its because Verizon has mandated all it's phones move to a single antenna setup, most likely to accelerate adoption of VoLTE.
Do you have evidence for that statement or are you just guessing? I was thinking it was more because single antenna designs are more battery and cpu reliable, and cheaper, so manufacturers are just building them this way. Buy, I'm just guessing...
You can do volte without a single antenna design.
I'm trying to understand your reply. You act as though I don't understand the fundamentals if how a smartphone works on Verizon.
Yes I know VoLTE can be done on both single and dual antenna phones.
Yes I know it saves battery having only one antenna.
Yes I know they can make call outside of LTE.
Yes I know they can access data outside of LTE.
Yes I know the Droid Turbo still has capability to connect to CDMA networks.
EVDO and CDMA aren't separate things. Both 1xRTT (2G) and EVDO (3G) are data transmission standards that are a part of CDMA technology. Just like EDGE and HSPA are data transmission standards that are part of GSM technology.
The WHOLE point if this was about SIMULTANEOUS voice and data. Something phones like the Turbo, Moto X 2014, Nexus 6, and others going forward won't be able to do until they support VoLTE. And considering the issues many seem to be having VoLTE aka Advanced Calling, they should have waited until it was more mature before stripping away simultaneous voice and data out of the box. Three years ago, we had the ability for simultaneous voice and data when they launched LTE. All of the devices from then to now had dual antennas. But now that they're starting to roll out VoLTE, they've stripped out one antenna, making it a data or voice, but not at the same time, which puts us functionally back to before LTE was launched. They shouldn't have tied simultaneous voice and data to VoLTE. They should've kept VoLTE separate until it was working as well as CDMA voice.
This. I am actually really shocked so many people are having issues with Verizon's VoLTE -- I figured if anyone can do it .. it would be them. On T-Mobile VoLTE works great .. and if I lose LTE for whatever reason .. It drops to HSPA and keeps the call going.
Hopefully Verizon can figure it out. I know with the Note 4 on Verizon they kept the dual radios .. Not sure why they decided to remove it for the Turbo.
I imagine Samsung forced the issue, especially considering no simultaneous voice and data until it got upgraded to Advanced Calling. That would probably put a dent in sales without that functionality out of the box.
