Phone Battery Drain with Pebble and/or Android Wear
Hello - I have a Droid Turbo, which I have used with both the Pebble and the LG G Watch (separately; Pebble app installed, removed, then Android Wear app installed then removed). My battery life has been fantastic (no problem getting through the day with up to 8.5 hours of screen on time). However, when I've installed Pebble and G watch (separately running each time) my battery drains considerably when the Pebble and/or Android Wear apps are installed - even if the watches are disconnected.
The problem is only fixed when I delete the Pebble and Android Wear apps. Neither app is referenced when I check the battery settings (though, even when the watches are disconnected, both the Pebble app and the Android Wear app is listed as running). I also did not notice any difference in any of the other battery settings.
I suspect this is some type of Bluetooth issue - any thoughts?
