I just got a Droid Turbo and wanted to know what was the best way to first calibrate the battery and then how to best keep it maintained going forward so it lasts as long as possible? Thanks for the help
And thats exactly how it should be charged, without any thought. We shouldnt have to worry about using any specific charger. I however feel the heat generated by the turbo charger will eventually cause battery problems. Maybe I am wrong but we wont know for at least a year. I usually keep phones for two years so I want it to last at least that long. Battery university showed pretty clearly heat for lithium ion batteries is not a good thing. I will use the turbo charger if I absolutely need to but otherwise I use a couple of old blackberry chargers and most of the house uses apple so chargers are always around.I was just asking because this is the first I've heard of such a thing, and I've had my Turbo for about a month, just using it and charging it whenever possible without any forethought. I also charge it overnight, given I've been told it that has no adverse effects.
I've only ever really charged it using the Turbo charger as well. Would I do better to use another charger?
Cracking me up man!!! And I havent seen you post anything that wasnt helpful. Threres about 4 or 5 posters here that pretty much post the same general ideas and all usually very helpful. I consider you to be in that group. I always carefully read what you and they post in the hopes of learning something. Thanks for the shout out though I appreciate it.EDIT: Foiled by mobrules posting something stellar seconds before me! j/k Yeah, listen to mobrules, much more specific and helpful.
