Factory reset question
Rogus
86
Is there a way to factory reset the DT without being able to use the screen which is broken and unusable? I hoping for some combination of button pushes as I want to wipe my info/data before sending it back now that I have my replacement phone.
PeterTheGeek
Active member
Jan 9, 2015
39
Press both lock and volume down when starting the phone to enter fastboot. And use volume rocker to view options and use power button to select.
Hope this can solve your problem.
ibcop
Trusted Member
Mar 9, 2011
3,572
37
Ha. He can't see the screen.
ibcop
Trusted Member
Mar 9, 2011
3,572
37
This is a good question as I know others have had to return their device after a replacement. I'm not certain the fast boot starts in the same place each time you enter it.
Rogus
86
Phone is currently powered on and I can see some colors in a small area of the screen, but I can't see anything to figure out where to scroll or even if I'm on the right screen. Not even sure how to power down when you can't see what's on or use the screen.
PeterTheGeek
Active member
Jan 9, 2015
39
See if there's software on computer that can do so. Or USB tether and cast screen?
1Coopgt
641
61
28
Did you set up an account over at Motorola Support ? I think you can do a remote wipe if you go to lost device . Not sure though .
Rogus
86
Right you can do a remote wipe if it was set up previously, but I already have the new phone activated and the old phone doesn't have cell service. You can't remote wipe unless the phone has service. I appreciate all suggestions in case I hadn't already thought of it.
doogald
Trusted Member
Jan 3, 2010
4,425
55
You should be able to if it is connected via wifi.
wei34
