I am having intermittent connect problems with the hotspot. Has anyone else had this problem? Has anyone found a fix?
Yes, a few others have encountered this issue after the Advanced Calling update. Search. Also, look in the Motorola Droid Turbo owners forum.I am having intermittent connect problems with the hotspot. Has anyone else had this problem? Has anyone found a fix?
Just spoke with Verizon Level 2 Tech Support. There is a bulletin out acknowledging a Mobile Hotspot connectivity issue caused by the Advanced Calling update. Verizon analysts are working with Motorola on a patch to resolve the issue. An update will be pushed out when the patch is available.I am having intermittent connect problems with the hotspot. Has anyone else had this problem? Has anyone found a fix?
