The navionics app that worked so well on my Droid 4 won't fully install on the turbo. It won't create a short cut. Anyone know how to create a shortcut manually?
I would suggest sending an email over to the developer regarding this issue: https://forums.androidcentral.com/e...s?id=it.navionics.singleAppUsa&token=WsEZZ8uEThe navionics app that worked so well on my Droid 4 won't fully install on the turbo. It won't create a short cut. Anyone know how to create a shortcut manually?
I would suggest sending an email over to the developer regarding this issue: https://forums.androidcentral.com/e...s?id=it.navionics.singleAppUsa&token=OxYKKiyd
Scroll down and find their contact information. It could be an issue with device support, or the version Android running on the Turbo. The Play Store says 4.0 and up is supported; however, there could still be conflicts that the developer does not know about.
