I'm having a very odd experience with my new Droid Turbo trying to get bluetooth audio to work as expected.
Expected behavior:
Actual behavior: as expected for steps 1-3 but the audio plays through the speaker and not the headset. Step 4 fails.
I can select 'disconnect' and 'connect' but nothing makes the media audio to come out of the headset. Please note: the headset is pairing and I can successfully make/take phone calls via the headset. I just can't seem to get the media audio to route correctly.
It's hard to explain, I made a video on Youtube but my score on here isn't high enough yet to post a link so this might not work: youtube.com/watch?v=gFuNpopLlSo You'll notice that no matter what the app says about being connected to the headset the audio always plays out the speaker.
I've tried:
The only thing I haven't tried is a factory reset of the phone. I really don't want to do that: it's only a few days old and it took me the better part of a day to install all the apps, copy data, etc.
The behavior is so consistent I'm coming reluctantly to the conclusion that I may have just missed some obvious option in the settings or audio control.
Interestingly, in desperation I tried installing 'SoundAbout', an app on the Play store that allows you to force certain things about bluetooth audio. With that app I was able to get the audio to play for a while, but when I went back (thinking I'd fixed the issue) it stopped working and even a remove/reboot/reinstall/reboot didn't make it work again.
Is this a bug? Or am I being dumb and missing some obvious setting?
Everything worked fine on my LG G3 and I'm puzzled why I can't route my audio out of my bluetooth headset on my Droid Turbo in the same way.
Expected behavior:
- Pair your bluetooth headset to your phone
- Make a call, the audio & mike are routed through the headset
- Hang up the call and open any app that makes a sound (say "Play Music" or "Youtube"). You see an icon showing your headset is connected and audio will be played via the bluetooth headset
- Press PLAY and the audio is heard through the headset
I've tried:
- Moto Hint and another bluetooth headset (the PS210 BTNC - full stereo A2DP)
- Factory reset of the headset
- Wiping the cache partition on my phone
- Rebooting
- Disabling and re-enabling bluetooth
- Disabling and re-enabling the Media Audio option under the Bluetooth settings for the headset (it is set to ON "use for media audio")
- Trying this test with another Android phone (LG G3 running Android 4.4.2) - it works as expected and does not display this issue
- Different apps (Play Music, Youtube, BeyondPod)
- Ensuring the headset is not connected to my Moto 360
- Removing all paired bluetooth devices except for the headset in question
- Disabling the Moto Connect features (e.g. silence during meetings, play via headphones while driving, etc.)
