Motorola Droid Turbo-Hissing Sound in Earpiece SOLVED
Okay, so here it is Everyone.
If you are Engaged in a Cell Phone Call and you as the USER of the Handest (Motorola Droid Turbo) are Experiencing a HISSING sound, there is a Simple Fix for this problem which after Several Months NOBODY has been able to come up with a solution. Not even our So-Called Verizon Wireless OR Motorola Engineers. Which goes to further PROVE how IN-Competent Verizon Wireless "Technical Support Staff, BOTH Tier-I and Tier-II" really are.
The FIX assuming your Motorola Droid is CURRENTLY Running System Version 21.44.12.quark_verizon.verizon.en.US
better known as android 4.4.4
1. Launch your Keypad Dialer (Stock)
2. Press the 3 Dots in Lower Right Corner and Select SETTINGS
3. Scroll Down and Check to ENABLE the Following:
Hearing Aids - Turn On Hearing Aid Compatability
Voice Privacy- Enable Enhanced privacy mode
THATS IT !!!!!!!!!!!!! Sit Back and ENJOY HD Receive Audio on your Motorola Droid Turbo with NO HISSING SOUND in the Earpiece. I dont use headsets or anything, so I have no way to verify if it corrects problem in Headsets, but I CAN VERIFY that it DOES Fix Hissing Sound in Earpiece.
If you have Advanced calling Activated on your Motorola Droid Turbo, you will Notice that this CORRECTS the issue as well and gives you Awesome Receive Audio in the earpiece. I have Tested & Re-Tested this Fix by Placing Phone Calls in mutiple different enviroments including a quiet room, walking inside a building with and without Noise in the background , Outside in Quiet and Noisy Enviroments , Lastly I tested this in a Moving Truck going down the highway with BOTH Windows Rolled Up and Rolled Down. The Receive Audio held Up to High Quality.
I then Called and Informed Verizon Wireless Technical Support Supervisors and Emailed BOTH Motorola Engineers and Verizon CEO's how they DO have an Issue with Receive audio and here is the Fix since NOBODY inside Verizon Wireless or Motorola Communications could Determine what the Issue was nor how-to repair the problem.
As Always, if you have any questions or feedback, please dont hesitate to let me know,
In the meantime, I am still going back to a Quality Device FREE of any problems like these kind of Quirks.
So Long Android , Im going back to my Trouble-Free Blackberry Z-30 where Problems Dont Exist and Secure Solutions Thrive.
