how do i restart the camera.it says camera error .please restart camera
I push the phone icon & it tells me .camera error please restart camera
Just open the camera.After I did a force stop, how do I start the camera again?
You can go into Settings, Apps, and open the camera application and Force Stop it. You can also power cycle the phone itself.
Hi... I just got stuck with this problem in my new Driod xt1080 about a week ago.
I tried each and every method.
*Restart my phone several times
*Factory reset
*Wipe cache partition
But all in vain.
Then i start the phone in factory mode
And the camera works for few seconds and then again restrat the camera.
Now this time i was very curious to find the solution ...
I removed the sim card from the phone and restart it..
And now the camera was absolutely gr8 as it should me... I put the sim back and changed the network settings... And now its all fine.
The setting are as under.
1. Global data roaming acess>allow acess for all trips.
2. Preferred network type>preferred network mode: Global....
It works great now..
Regards..
