SUCCESSFULLY RECOVERED!
I tripped up on he RTL option just by trying to scroll up... stoopid, stoopid stoopid...
@EINSTEINDKS - THANKS, I am a "Day Late and A Dollar Short" but net time I am curious I will try a quick Googling to satisfy my curiosity - thanks again for the No Brainer, doh! Anyway...
...I fixed my Motorola Droid Turbo fixed by using this
ALTERNATE METHOD here --> (
Factory Data Reset (Powered Off) - DROID TURBO by Motorola | Verizon Wireless )
(WHICH I found on the
original link posted above --> (
Factory Data Reset (Powered On) - DROID TURBO by Motorola | Verizon Wireless ).
STEP 4. Was a little quirky and gave me doubts but eventually worked just fine.
I also have 2-Step verification enabled (plus the GOOGLE AUTHENTICATOR) and had no alternate codes saved off BUTwas lucky enough to have previously supplied Google with my HOME telephone number AD that was utilized as a successful option to sign back in (TWICE - not sure why BUT the SIGIN process ran twice concurrently so I had to enter:
1. NAME1, PW1, 6 - Digit Code1, Restore from BackUp1 --> THEN AGAIN --> NAME2, PW2, 6 - Digit Code2, Restore from BackUp2 -->
THAT WAS SCARY, THANKS EVERYONE FOR HELPING OUT !!!
Sincerely,
-AdMan
P.S. Seems kind of Ironic that the resolution to this issue is listed on a VERIZON support page seeing how if VERIZON had their act together my Verizon DROID TURBO would be running MARSHMALLOW like my Wive's Verizon GS5 and then maybe this would not have happened. -AdMan
