The only big block of awake time overnight was at about 3 am. Otherwise, it looks normal. There isn't any screen on time (so the screen isn't turning on without being used) and location services are practically nothing. The period after you awoke was fairly normal - awake while charging (as expected) and a large block of awake time with screen off just before you took the screenshot - were you listening to music (or other media) or talking on the phone with the screen off during this time? If yes, that's expected awake time, too.
25% in that short of a time sounds like too high a drain, but, there are a few things that could be up:
1. How old is the phone? It could be that the battery is fatigued and not holding charge as well as when new.
2. The battery usage calculation is miscalculating. This can happen over time.
To rule out/fix number 2, I'd suggest doing a calibration run, at some point when you know you'll have time (over the weekend?) Run the battery down until the phone says it will shut off due to too low a charge, then plug it in and keep it plugged in until it is at 100% charge. To hasten the discharge, you could do something like watch video/Netflix/etc. with the battery saver turned off. If you have battery miscalibration, when the battery gets very low you may see it stay at that level for a lot longer than it should (i.e, if it takes 30 minutes to get from 60 to 50, it may take a lot longer to get from 10 to 0).
It could be important to be actively using the phone when you are doing this, so that you can monitor when the phone gets to the shut down point. Some people are unable to get the battery to charge at all if it has been sitting below the ability to start the phone for a long time (though, saying this, I have done this with my old Droid Maxx a couple of times when I left it on accidentally when I meant to shut it down and it sat about a week after shutting off on its own, and my Maxx is definitely older than your Turbo.)
Good luck, I hope that you figure it out.
(I wish Android gave better reporting tools about app usage...)
