connect damaged turbo to tv & remote keyboard
mikeypop1948
5
I have a turbo with a damaged screen that is dark. I want to connect to a TV and a remote keyboard to access messaging. I have a new replacement & would like to transfer messaging to it or to my laptop. How can I do so?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Welcome to Android Central! The Turbo supports Miracast, but not MHL or Slimport. So you'd need a TV that supports Miracast (or a Miracast adapter). Also, do you know if the screen still registers touches?
mikeypop1948
5
Belkin has an adaptor. Do you know if the screen must be usable in order to tell the adaptor to cast the screen to the TV? Any advice concerning the remove keyboard interface?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
If the screen doesn't register touches, then try a basic USB mouse connected via OTG cable.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
I don't think the phone needs the Miracast adapter, because it should already have it built in. The TV would need to be compatible with Miracast, so that's where you might need to plug in an adapter.
fallingOutOfLoveWfithTech
